Implementing Siebel Business Applications on DB2 UDB for z/OS > Customizing a Development Environment >
Process of Cloning a DB2 for z/OS Database
You can clone your existing Siebel database to a target database. The DB2 system cloning process involves the following tasks:
- Extracting a Storage Control File from the DB2 Catalog
This involves extracting a storage control file from the existing Siebel Schema.
- Generating a DDL File from a Storage Control File
Use the extracted storage control file to generate a DDL file that you can apply to create a clone of the Siebel Schema.
