Implementing Siebel Business Applications on DB2 UDB for z/OS > Preparing for Implementation on the DB2 Host > Setting Up the DB2 Subsystem > Advantages of Using a Separate DB2 SubsystemSiebel Systems supports production deployments of Siebel Business Applications in both separate and shared DB2 subsystems. However, setting up a separate subsystem for Siebel applications is preferable, particularly for larger deployments, for the following reasons:
Even though a separate DB2 subsystem is preferable for implementing Siebel Business Applications, there are numerous successful Siebel deployments in shared DB2 subsystems. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
