Implementing Siebel Business Applications on DB2 UDB for z/OS > Installing the Siebel Database Server Files at Midtier >
Reviewing the Software Installation for DB2 for z/OS
Review the directory structure created by the Siebel Database Server installation for your operating system, as illustrated in this section (this may vary depending on whether you performed a typical or a custom installation).
Windows Installation Directory for DB2 for z/OS
The db2390 subdirectory is located under the DBSRVR_ROOT directory within the Siebel root directory you specified during the installation, for example, C:\sea78\dbsrvr\db2390\.
DBSRVR_ROOT
BIN
COMMON
DB2UDB
DB2390
DBOUTPUT\
DDLSYNC
DEV2PROD
INSTALL
INSTALLDW
UPGRADE
STORPROC
UPGRADE
LANGUAGE
(for example, ENU)
DB2UDB
DB2390
MSSQL
ORACLE
FILES
LOCALE
MSSQL
ORACLE
PE60
  • BIN. Contains files for internal use.
  • COMMON. Contains common database platform-independent files.
  • DB2UDB. Contains language-specific installation and upgrade files for DB2 UDB.
  • DB2390. Contains language-specific installation and upgrade files for DB2 for z/OS.
    • DBOUTPUT. Contains subdirectories in which DDL is deposited by the installer for later transfer to the DB2 host when the Siebel Schema installation option, Generate DDL Into Files, is chosen.
      The subdirectories of DBOUTPUT contain DDL specific to the following Siebel processes:
      • DDLSYNC. Related to synchronization of the Siebel Schema definition.
      • DEV2PROD. Related to migrating development customizations to the test or production environment.
      • INSTALL. Contains all installation files for the Generate DLL into Files option, used to create the Siebel Schema directly on the mainframe.
      • INSTALLDW. Contains all files necessary to install the Siebel Data Warehouse.
      • UPGRADE. Related to version upgrade activities.
    • STORPROC. Contains stored procedures required for upgrades.
    • UPGRADE. Contains subdirectories containing files to allow upgrades from specific versions of Siebel Business Applications to the current release.
  • LANGUAGE. Contains language- and database-specific files for the ancestor repository and supporting files. For example, ENU contains U.S. English-language-specific files, and DEU contains German language-specific files. Additional subdirectories exist under this level, based on the language packs that you install.
  • FILES. Contains sample file attachments. These should be copied to the appropriate subdirectory within the Siebel File System. See Populating the Siebel File System.
  • LOCALE. Contains translation files for the Upgrade Wizard. For Siebel Systems use only.
  • MSSQL. Contains language-specific installation and upgrade files for MSSQL.
  • ORACLE. Contains language-specific installation and upgrade files for ORACLE.
  • PE60. Files used for uploading data from Siebel Sales Personal Edition.
UNIX Installation Directory for DB2 for z/OS
Review the directory structure created by the Database Server installation for UNIX, as illustrated in this section (this may vary depending on whether you performed a typical or a custom installation).
$DBSRVR_ROOT
bin
common
db2udb
db2390
dboutput/
ddlsync
dev2prod
install
installdw
upgrade
storproc
upgrade
language
(for example, enu)
db2udb
db2390
mssql
oracle
files
locale
oracle
  • bin. Contains files for internal use.
  • common. Contains common database platform-independent files.
  • db2udb. Contains language-specific installation and upgrade files for DB2 UDB.
  • db2390. Contains installation and upgrade files specific to DB2 for z/OS.
    • dboutput. Contains subdirectories in which DDL is deposited by the installer for later transfer to the DB2 host when the Siebel Schema installation option, Generate DDL Into Files, is chosen.
      The following subdirectories contain DDL specific to the following Siebel processes:
      • ddlsync. Related to synchronization of the Siebel Schema definition.
      • dev2prod. Related to migrating development customizations to the test or production environment.
      • install. Contains all installation files for the Generate DLL into Files option, used to create the Siebel Schema directly on the mainframe.
      • installdw. Contains all files necessary to install the Siebel Data Warehouse.
      • upgrade. Related to version upgrade activities.
    • storproc. Contains stored procedures required for upgrades.
    • upgrade. Contains subdirectories containing files to enable upgrade from specific versions of Siebel Business Applications to the current release.
  • language. Contains language- and database-specific files for the ancestor repository and supporting files. For example, enu contains U.S. English-language-specific files, and deu contains German-language-specific files. Additional subdirectories may exist under this level, based on the language packs that you install.
  • files. Contains sample file attachments. These should be copied to the appropriate subdirectory within the Siebel File System. See Populating the Siebel File System.
  • locale. Contains translation files for the Upgrade Wizard. For Siebel Systems use only.
  • oracle. Contains language-specific installation and upgrade files for ORACLE.
