Implementing Siebel Business Applications on DB2 UDB for z/OS > Siebel Repository Import and Postinstallation Tasks > Postinstallation Tasks for the Siebel Repository > Granting Table PrivilegesThe database administrator edits and executes the file, grantstat.sql, located within the To edit and run the grantstat.sql script
NOTE: If you use multiple security groups, grant this privilege to each group. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
