Implementing Siebel Business Applications on DB2 UDB for z/OS > Migrating Data Using Siebel EIM > About Setting Up EIM for DB2There are many ways you can optimize EIM data throughput. EIM is similar in function to other DB2 applications, so use regular performance monitoring tools to monitor and fine-tune performance. You should review and tune performance for each set of business data you load with EIM, for example, Opportunities, Contacts, or Products. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
