Implementing Siebel Business Applications on DB2 UDB for z/OS > Understanding Siebel Partitioning > Example of Partitioning: the S_ADDR_ORG Table >
Performance Overhead of Using a Trigger
The performance overhead of using a trigger is measured as a percentage of the inserts. Performance overhead depends on several factors, including row length and the number of indexes in the table.
Triggers that use the S_PARTY partitioned table space, 10 partitions, 14 columns, and 443 bytes with 8 indexes, have demonstrated a performance overhead of less than one percent per insert.
