Implementing Siebel Business Applications on DB2 UDB for z/OS > Understanding Siebel Partitioning > Partitioning Strategies for Special Types of Tables > The S_ESCL_REQ and S_ESCL_LOG TablesThe tables S_ESCL_REQ and S_ESCL_LOG, which are used by Assignment Manager and Siebel Business Process Designer, tend to grow very large. S_ESCL_REQ is processed based on the GROUP_ID, whereas S_ESCL_LOG is processed by RULE_ID. You can partition these tables in one of the following ways:
NOTE: If resource contention occurs because multiple groups are using the same partition, consider increasing the number of partitions when you create new groups and assign new group IDs; this allows for a more granular level of GROUP_ID assignments to a partition range. |
Implementing Siebel Business Applications on DB2 UDB for z/OS |
