Siebel Life Sciences Guide > Closing Adverse Events and Complaints >
Reviewing Approvals for Product Issues (End User)
Any change to the Status field for the product issue record is recorded in the Approvals view. Use the Approvals view to see who has changed that status of the product issue and when the change was made.
To use approval tracking, you must have Audit Trail turned on. For information about Audit Trail, see Siebel Applications Administration Guide.
To view approvals for a product issue
  1. Navigate to Product Issues screen > Product Issue List view.
  2. Drill down on a product issue.
  3. Click the Approvals view tab.
    In the read-only list, you can view all approvals to the product issue.
Siebel Life Sciences Guide Copyright © 2008, Oracle. All rights reserved.
