Priority |
The priority of the benefit in relation to other benefits. |
Name |
The name of the benefit; for example, Rebate on Stents. |
Type |
The type of benefit; for example, Credit or Rebate. |
Schedule |
The benefit schedule; for example, Quarterly. |
Amount |
The total amount of the benefit in the unit defined in the U/M field. |
U/M |
The unit in which the benefit is measured; for example, Percent. |
Status |
The current status of the benefit; for example, Active or On Hold. |
Action Basis |
The basis for evaluating or delivering the benefit; for example, if the Benefit is triggered by an invoice for a particular quantity of stents, Action Basis=Invoice. |
Action Method |
The action produced by the Action Basis; for example, if an allowance is administered by adjusting the invoice, Action Method = Adjustment. |
Current Amount |
The existing amount of the benefit including any adjustments already made, or the current liability for the benefit. |
Description |
A brief description of the benefit. |
Benefit Basis |
Used when the Benefit Amount is variable and is calculated based on another value; for example, 10% of Invoice Amount, Benefit Basis = Invoice Amount. |
Benefit Price |
Used when the Benefit Amount is variable and is calculated based on another value; for example, for a 5% discount, the Benefit Price specifies the starting price for Siebel Pricer. |
Benefit Constraint |
Indicates the maximum or minimum amount of the Benefit when it is calculated using Benefit Basis and/or Benefit Price. |
Tier |
Enables benefits to be defined differently for different tiers; for example 10% discount for Tier 1, 15% discount for Tier 2, where the volume of purchases determines the appropriate tier. |
Division |
Defines the Division to which the Benefit applies; for example, 10% rebate for all products purchased by the Cardiology Department of University Hospital. |
Product Category |
Indicates the product category associated with the benefit. |
Product |
Indicates the product associated with the benefit; for example, 1 free Xygo Lead for every 40 Lead purchases, Product = Xygo Lead. |
Product Line |
Indicates the product line associated with the benefit. |
Product Class |
Indicates the product class associated with the benefit. |
All Products |
Indicates that All Products are associated with the benefit. |
Level |
Indicates the level at which the benefit applies; for example, Account, Agreement, Entitlement. |
Comments |
Used to capture additional comments related to the benefit. |
Reset |
Can be used to indicate that the benefit should be reset; for example, the benefit should be reset if exhausted, when the agreement is renewed or annually. |
Conditions Relationship |
Indicates all conditions must be met ("and") or only one condition must be met ("or") in order to deliver the benefit. |
Adjustment Amount |
Used when Action Method = Adjustment to indicate the amount of the adjustment. |
Adjustment Currency |
Indicates the currency associated with the Adjustment Amount. |
Adjustment Exchange Date |
Specifies the Exchange Date for the Adjustment Currency. |
Amount Currency |
Specifies the currency when U/M = Currency. |
Amount Exchange Date |
Specifies the exchange date for the Currency indicated by Amount Currency. |
Count Method |
Indicates whether the Current Amount should be incremented (to track the amount of benefit delivered) or decremented (to track remaining liability) when the benefit is delivered. |
