Siebel Life Sciences Guide > Managing CAPAs > Creating a CAPA Record (End User)Corrective actions can be created and viewed in these screens:
When a CAPA is created from the Product Issues or the Repairs screen, a CAPA number is assigned automatically. You can configure the application to copy information from the Product Issue or the Product Analysis record to the CAPA record. Review the configuration of the Create Product Issue button (see About Configuring Adverse Events and Complaints Capture) for an example of a similar configuration. This task is a step in Process of Managing CAPAs. To create a CAPA record in the Corrective Actions screen
Siebel Life Sciences Guide | Copyright © 2008, Oracle. All rights reserved. | |
