Siebel Life Sciences Guide > Using Personalized Content Delivery > Working with Messaging Plans >
Providing Access to Messaging Plans
You can control access to the messaging plan, presentation items, related messages, and detailed messages.
To assign access groups to a messaging plan
  1. Navigate to Messaging Plans > Messaging Plan List view.
  2. In the Messaging Plan list, select a record, and drill down on the Name field.
  3. Click the Access Group tab, and then click Add to add access group details for the messaging plan.
    Some fields are described in the following table.
    Field
    Description
    Category Name
    Enter the category name associated with the messaging plan, presentation items, related messages, and detailed messages.
    Display Name
    Enter the display name for the access group.
    Catalog Name
    Enter the catalog name used to control access to the messaging plan, presentation items, related messages, and detailed messages.
    Description
    Enter a description for the access group.
    Effective Start Date
    Enter the date when the catalog becomes visible to the assigned users.
    Effective End Date
    Enter the date when the catalog will no longer be visible to the assigned users.
  4. Select a record, and click Delete if you want to remove an access group.
  5. Click Refresh Cache to view the recent changes to your messaging plans.
Siebel Life Sciences Guide Copyright © 2008, Oracle. All rights reserved.
