Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty >
Defining Loyalty Member Phases
The Member Phase picklist is used for specifying phases of member types. Typical values are Gold - Phase 1, Gold - Phase 2, Platinum - Phase 1, and Platinum - Phase 2.
To define Loyalty groups, classes, and phases
  1. Navigate to the Administration - Data > List of Values view.
  2. Query for the Type LOY_MEM_PHASE.
  3. Edit the records of this type so there is one record with each of the display values that you want for member phases.
  4. Click Clear Cache.
    NOTE:  New values do not go into effect unless you click Clear Cache.
