Siebel Loyalty Administration Guide > Getting Started with Siebel Loyalty > Defining Lists of Values for Siebel Loyalty >
Defining Loyalty Airport Codes
Airline companies must define airport codes for all airports that flights arrive at and depart from. This allows you to select these codes in the From Airport and To Airport drop-down lists when you define products.
To define airport codes
  1. Navigate to the Administration - Data > List of Values view.
  2. Query for the Type LOY_AIRPORT_CODE_CD.
  3. Add one record with this Type value for each airport your flights arrive at or depart from.
