Siebel Loyalty Administration Guide > Host Organization's Use of Siebel Loyalty >
Entering and Viewing Loyalty Members' Value Scores
As the member value score, you can select a number from 1 to 5, to indicate the member's value as a customer.
To enter or view a member's value score
  1. Navigate to the Loyalty Members screen.
  2. In the Members list, select the member and click its Member # hyperlink.
  3. Click the More Info view tab.
    The member's value score appears in the Member Value section, in the Lifetime Value Score field.
  4. To enter the member's value score, select a value in the Value Score field.
