Siebel Loyalty Administration Guide > Using Siebel Loyalty with Partners >
Entering the Loyalty Partner Program Profile
In order to help you understand a partner's loyalty program, you can enter information in the partner program profile. This only applies to partners who have their own loyalty programs. This task is a step in Process of Setting Up Partner Access to Siebel Loyalty. To add programs to the partner program profile
- Navigate to the Loyalty Program Administration screen.
- Identify the program to which you want to add partners, and click its Program Id hyperlink.
- Click the Programs Hosted view tab.
- On the Partners list, click New.
- In the Add Partner dialog box, select a partner to associate with this program and click OK.
To view the partner program profile
- Navigate to the Partners screen.
- In the link bar, click Partner List.
- Identify the partner company whose profile you want to view and click its Partner Name hyperlink.
- Click the Partner of Programs view tab.
The Partner of Programs list displays a record for each of the partner's loyalty programs. Some fields are described in the following table.
Name |
Enter the name of the partner's loyalty program. |
Hosted By |
Enter the name of the host organization for this program. |
Promotion Calculation Rule |
Enter the method that the partner uses to calculate points. |
Start Date |
Enter the date the partner began offering its program. |
