Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > About Adding Marketing Information to Loyalty Promotions >
Creating Goals and Assumptions for Loyalty Promotions
You can create one or more goals for a promotion. For each goal, you can create one or more assumptions.
NOTE:  To create goals and assumptions for a promotion, you must first associate the promotion with a marketing campaign. For instructions on associating Siebel Loyalty promotions with Siebel Marketing campaigns, see the chapter on planning and budgeting in Siebel Marketing User Guide.
To create goals for a loyalty promotion
  1. Navigate to the Loyalty Promotions Administration screen.
  2. In the Promotions list, find the promotion to which you want to add goals and click the hyperlink in its Promotion # field.
  3. If the promotion form's Active check box is selected, click Modify.
  4. Click the Goals view tab.
  5. Add one or more new records to the Goals list, and complete the necessary fields in each record. Some fields are described in Table 15.
    Table 15. Fields in the Goals and Assumptions Lists
    Field
    Comments
    Metric
    Type of measure, such as currency or units, that the goal or assumption pertains to
    Number Format
    If the metric is a numeric one, format in which the number is displayed
    Target Amount
    If the metric is a currency one, money amount that the goal or assumption targets
    Target Qty
    If the metric is a numeric one, numeric quantity that the goal or assumption targets
    Forecast Amount
    If the metric is a currency one, money amount predicted for the goal or assumption
    Forecast Qty
    If the metric is a numeric one, numeric quantity predicted for the goal or assumption
To create assumptions for a loyalty promotion goal
  2. In the Promotions list, find the promotion to which you want to add assumptions and click the hyperlink in its Promotion # field.
  5. In the Goals list, select the goal to which you want to add assumptions.
  6. Add one or more new records to the Assumptions list below the Goals list, and complete the necessary fields in each record. Some fields are described in Table 15.
