Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Process of Approving Loyalty Promotions >
Submitting Promotions for Approval
After developing promotions, loyalty administrators submit promotions for management approval.
This task is a step in Process of Approving Loyalty Promotions.
To submit a promotion for approval
  1. Navigate to the Loyalty Promotions Administration screen.
  2. In the Promotions list, find the promotion that you want to submit for approval.
  3. If the promotion form's Active check box is selected, click Modify.
  4. In the promotion form, click the Show More button to display the Approval Status field.
  5. In the Approval Status field, change the selection from In Progress to Submitted.
    The system sends this promotion to the designated manager's approvals queue.
