Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > About Controlling the Availability of Loyalty Promotions > Deactivating Loyalty PromotionsYou can deactivate a promotion so it is no longer available to users. When you do this, the promotion will not generate extra rewards for members, and it will not be visible to your employees using the Loyalty Promotions screen, to Partners using the Partner Portal, or to members using Siebel eLoyalty. After deactivating a promotion, you can reactivate it by following the instructions in Activating Loyalty Promotions. |
Siebel Loyalty Administration Guide |
