Siebel Loyalty Administration Guide > Setting Up Siebel Loyalty Promotions > Process of Creating Loyalty Promotions >
Creating a Loyalty Promotion Record
The Promotion record includes general information about the promotion, such as its name, when it is in effect, and whether it requires enrollment.
This task is a step in Process of Creating Loyalty Promotions.
To create a loyalty promotion record
  1. Navigate to the Loyalty Promotions Administration screen.
  2. Add a new record to the Promotions list, and complete the necessary fields in the record and in the More Info form. Some fields are described in the following table. You must expand the More Info form to view some of these fields.
    Field
    Comments
    Apply To
    Select which type of transaction the promotion applies to. The options are Accrual-Product, Loan, Redemption-Product, Cancellation, Accrual-Gift, Bonus, and Voucher. If you leave this field blank, the promotion can apply to all types of transactions.
    Active
    This check box is selected if the promotion is active. You cannot select or deselect it manually. It changes when you click the Activate, Deactivate, or Modify button.
    Always Apply
    Select this check box to make this promotion always apply, regardless of the choice you made in the Promotion Calculation Rule for the loyalty program that this promotion is part of. For more information, see About Promotion Calculation Rules for Loyalty Programs.
    Enrollment Required
    Select this check box to require members to enroll for the promotion in order to get the reward. If it is not checked, all members of the program receive the reward for this promotion without enrolling in it.
    Promotion Start and Promotion End
    Enter the date when the promotion starts and ends. Products purchased between these dates qualify for the promotion reward.
    Enrollment Start and Enrollment End
    If this promotion requires enrollment, enter the dates when members can enroll. In general, these dates should fall within the promotion's start and end dates.
    Product Inclusion
    Select which products the promotion applies to. The options are:
    • All Products. Applies to all products.
    • Include Products. Applies only to products listed in the Products view of the Loyalty Promotion Administration screen.
    • Exclude Products. Applies only to products not listed in the Products view of the Loyalty Promotion Administration screen.
    Point Limit Type
    Select Limited if the points awarded will be taken from a point block created specifically for this promotion. Select Unlimited if the points will be taken directly from the company's or partner's point blocks, without limit. For more information, see Providing Point Blocks for Loyalty Promotions.
    Partner
    Select the company that the promotion is hosted by. This is the company whose point block is debited when members earn points as a result of this promotion. It can be a partner company or the host company.
    Partner Action On
    Displays the date and time when the partner approved or rejected the promotion. You must expand the Promotion form to see this field.
    Partner Action By
    Displays the login name of the partner who approved or rejected the promotion. You must expand the Promotion form to see this field.
