Siebel Loyalty Administration Guide > Siebel Loyalty Workflows and Methods Reference > LOY Processing Engine Business Service >
SubmitObjectForProcessing Method
SubmitObjectForProcessing is called when the user clicks the Process button of the UI to process a transaction in real time. If the application is running in server mode, then it submits a synchronous component request to the specified component (with specified workflow and row id). Otherwise, it directly invokes the workflow to process the object in the same thread.
Input Arguments
Name
Value
Description
Component
String
The name of the component to submit the request to
ProcessName
String
The workflow to invoke
RowId
Row Id
The Row Id of the Object to Process
Output Arguments
None
