Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > SOAP Calls for Marketing >
deleteResultSet Method
API Definition
Method
<binding name="JobManagementService" type="i0:JobManagementServiceSoap">
   <soap:binding transport="http://schemas.xmlsoap.org/soap/http" style="document" /> <operation name=" deleteResultSet ">
      <soap:operation soapAction="#deleteResultSet" style="document" />
      <input>
         <soap:body use="literal" />
      </input>
      <output>
      </output>
   </operation>
</binding>
Method Input
<xsd:element name=" deleteResultSet ">
   <xsd:complexType>
      <xsd:sequence>
         <xsd:element name="targetLevel" type="xsd:string" minOccurs="0" maxOccurs="1" />
         <xsd:element name="GUIDs" type="sawsoap:arrayOfGUIDs" minOccurs="0" maxOccurs="1" />
         <xsd:element name="segmentPath" type="xsd:string" minOccurs="1" maxOccurs="1" />
         <xsd:element name="deleteOption" minOccurs="0" maxOccurs="1" default="all" />
            <xs:simpleType>
               <xs:restriction base="xs:string">
                  <xs:enumeration value="mostRecent" />
                  <xs:enumeration value="oldest" />
                  <xs:enumeration value="all" />
               </xs:restriction>
            </xs:simpleType>
         <xsd:element name="sessionID" type="xsd:string" minOccurs="0" maxOccurs="1" />
      </xsd:sequence>
   </xsd:complexType>
</xsd:element>
<xsd:complexType name="arrayOfGUIDs">
   <xsd:sequence>
      <xsd:element name="GUID" type="xsd:string" minOccurs="0" maxOccurs="unbounded" />
   </xsd:sequence>
</xsd:complexType>
Method Output
<xsd:element name="deleteResultSetResult">
   <xsd:complexType>
      <xsd:sequence>
         <xsd:element name="jobInfo" type="sawsoap:JobInfo" />
      </xsd:sequence>
   </xsd:complexType>
</xsd:element>
Valid Usage Scenarios
Deletes one or more saved result sets of target level objects identified by a list of GUID values belonging to a segment.
<deleteResultSet>
   <targetLevel>[target level the saved result set contains]</targetLevel>
   <GUIDS>
      <GUID>[GUID value for saved result set 0]</GUID>
      <GUID>[GUID value for saved result set 1]</GUID>
      <GUID>[GUID value for saved result set N]</GUID>
   </GUIDS>
   <segmentPath>[path to the segment]</segmentPath>
</deleteResultSet>
Usage Options
None.
Siebel Marketing Installation and Administration Guide Copyright © 2006, Oracle. All rights reserved.
