Siebel Marketing Installation and Administration Guide > Installing and Configuring Email Marketing > SOAP Calls for Marketing >
prepareCache Method
The prepareCache method caches a segment or a segment tree for list export.
API Definition
<xsd:element name="prepareCache">
   <xsd:complexType>
      <xsd:sequence>
         <xsd:element name="segmentPath" type="xsd:string" minOccurs="0" maxOccurs="1" />
         <xsd:element name="treePath" type="xsd:string" minOccurs="0" maxOccurs="1" />
         <xsd:element name="refresh" type="xsd:boolean" default="false" minOccurs="0" maxOccurs="1" />
         <xsd:element name="sessionID" type="xsd:string" minOccurs="0" maxOccurs="1" />
      </xsd:sequence>
   </xsd:complexType>
</xsd:element>
<xsd:complexType name="treeNodePath">
   <xsd:sequence>
      <xsd:element name="treePath" type="xsd:string" minOccurs="1" maxOccurs="1" />
      <xsd:element name="treeNodePriority" type="xsd:string" minOccurs="0" maxOccurs="1" />
      <xsd:element name="treeNode" type="xsd:string" minOccurs="0" maxOccurs="1" />
   </xsd:sequence>
</xsd:complexType>
Valid Usage Scenarios
Caches the segment for list export.
<prepareCache>
   <segmentPath>[path to the segment]</segmentPath>
</prepareCache>
Caches the segment tree for list export.
<prepareCache>
   <treePath>[path to the segment tree]</treePath>
</prepareCache>
Usage Options
None.
Siebel Marketing Installation and Administration Guide Copyright © 2006, Oracle. All rights reserved.
