Siebel Marketing Installation and Administration Guide > Advanced Marketing Information for Administrators > Displaying Analytics Columns in Marketing Plans > Displaying Analytics Columns in Marketing Plans By Exporting SchemaSiebel Marketing supports the ability to display the value of any Analytics column as a field in a form or list applet. The standard version of Siebel Analytics uses this capability to calculate actual revenue for a marketing plan. Use the Siebel Analytics Administration Tool to export the corresponding schema, create an XML file (table) from the exported schema information, and import the XML file back into the Physical layer of the Administration Tool as an XML data source. For more information about exporting schemas and importing data sources, read Siebel Analytics Server Administration Guide. Alternatively, you can display values from a Siebel Analytics column by creating an external table object in Siebel Tools. This external table object contains a logical column and logical join so that you can retrieve an external column value from Siebel Analytics. |
Siebel Marketing Installation and Administration Guide | Copyright © 2006, Oracle. All rights reserved. | |
