Siebel Marketing Installation and Administration Guide > Installing and Administering Siebel Marketing >
Importing Marketing iHelp Files from the Demo Database
The demo database includes many iHelp files that can help users through frequently used tasks. The following section provides instructions for exporting any of the iHelp examples included. NOTE: Oracle has developed a library of available tasks for Marketing tasks that are not part of the demo data/sample database. To obtain a copy of these iHelp files, please read Oracle's Siebel SupportWeb, or contact a representative from Oracle's Product Marketing or Oracle's Siebel Technical Support for assistance.
To export a task from the demo database
- Connect an instance of an application to the demo database.
- Navigate to Administration - iHelp screen > All iHelp Items.
- Select a task to export.
- In the iHelp Items list menu, choose Export iHelp Item Definition.
- In the File Download dialog box, click Save and save the XML file anywhere on your computer's file system or anywhere on your network.
You can access the file later when you are ready to import it into another environment.
To import the task in your new installation
- In the iHelp Items list menu, choose Import iHelp Item Definition.
- In the Import iHelp Item Definition dialog box, select the XML file from the location on your computer or network where you stored the task.
- Click the Designer tab.
A flowchart of the steps appears.
- Click the Responsibilities tab and associate the responsibilities that should have access to this set of instructions.
- In the All iHelp Items list, select the iHelp item record and click Activate.
- Test the iHelp task by going to a screen related to the task and clicking the How do I icon in the top-left view bar.
