Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods >
GetSearchExpr Method
GetSearchExpr returns the current search expression for the business component.
Not applicable
A string containing the current search expression. An example of a returned search expression string is "Revenue > 10000 AND Probability > .5".
GetSearchSpec retrieves the business component state, not the values. The business component state does not change until the query is executed. Note that it may never change to the original value if the user input is invalid.
When using GetSearchExpr in a browser script and the Applet_PreInvokeMethod, GetSearchExpr returns a null value even if a query filter has been added.
Used With
Browser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script
See Also
GetNamedSearch Method
GetSearchSpec Method
SetSearchExpr Method
