Siebel Object Interfaces Reference > Interfaces Reference > Business Component Methods > GetUserProperty MethodGetUserProperty returns the value of a named user property. SyntaxBusComp.GetUserProperty(propertyName) ReturnsUsageThe value of a user property is set using SetUserProperty. The user properties act like instance variables of a business component. The advantage of user properties is that they can be accessed from anywhere in the code (even from other applications through COM) using GetUserProperty. An instance variable, on the other hand, can be accessed only from within Siebel VB from the same object on which the variable is declared. The value of the property is reset every time you instantiate a new business component. NOTE: GetUserProperty does not interact directly with user properties defined in Siebel Tools. Used WithCOM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script See Also |
Siebel Object Interfaces Reference |
