Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events >
BusComp_ChangeRecord Event
The ChangeRecord event is called after a record becomes the current row in the business component.
Not applicable
Not applicable
Code in the ChangeRecord event handler is executed each time that the focus changes to another record. Avoid lengthy operations in this event handler to enable smooth scrolling in list applets.
Used With
Server Script
This Siebel VB example uses two subprograms in the (general) (declarations) section to set up an audit trail for service requests. The ChangeRecord event handler is used to initialize the values from the service record so that they can be compared with current values.
Option Explicit
Dim OldClosedDate, OldCreated, OldOwner, OldOwnerGroup
Dim OldSeverity, OldSource, OldStatus
Declare Sub CreateAuditRecord
Declare Sub InitializeOldValues
Sub CreateAuditRecord (FieldName As String, NewValue As String, OldValue As String, ChangedText As String)
   Dim ActionBC As BusComp
   Dim CurrentBO As BusObject
   Dim theSRNumber
   Set CurrentBO = TheApplication.GetBusObject("Service Request")
   Set ActionBC = CurrentBO.GetBusComp("Action")
   theSRNumber = GetFieldValue("SR Number")
   With ActionBC
      .ActivateField "Activity SR Id"
      .ActivateField "Description"
      .ActivateField "Private"
      .ActivateField "Service request id"
      .ActivateField "Type"
      .NewRecord NewAfter
      .SetFieldValue "Activity SR Id",      theSRNumber
      .SetFieldValue "Description",         ChangedText
      .SetFieldValue "Private",               "Y"
      .SetFieldValue "Type",                "Administration"
   End With
End Sub
   OldClosedDate = GetFieldValue("Closed Date")
   OldOwner = GetFieldValue("Owner")
   OldSeverity = GetFieldValue("Severity")
   If GetFieldValue("Severity") <> OldSeverity Then
      NewValue = GetFieldValue("Severity")
      ChangedText = "Changed Priority from " + OldSeverity + _
         " to " + NewValue
      CreateAuditRecord "Severity", NewValue, OldSeverity, _
   End If
End Sub
Sub BusComp_ChangeRecord
End Sub
