Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events >
BusComp_DeleteRecord Event
The DeleteRecord event is called after a row is deleted. The current context is a different row (the Fields of the just-deleted row are no longer available).
Syntax
Argument
Description
Not applicable
Usage
When a user reads and deletes an existing record or creates and undoes a new record, this invokes DeleteRecord. This invocation causes any associated scripts to be executed.
Returns
Not applicable
Used With
Server Script
