Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events >
BusComp_PreGetFieldValue Event
The PreGetFieldValue event is called when the value of a business component field is accessed.
Syntax
BusComp_PreGetFieldValue(FieldName, FieldValue)
Argument
Description
FieldName
String containing the name of the field accessed
FieldValue
String containing the value accessed
Returns
ContinueOperation or CancelOperation
Usage
PreGetFieldValue is called at least once for each user interface element that displays the BusComp field value, and it may also be called as a result of other internal uses.
NOTE:  PreGetFieldValue is called every time the user interface is updated to repaint fields on the screen. Therefore, a script attached to this event runs very frequently, which may cause the computer to appear to be unresponsive.
Even empty scripts are invoked by the framework and thus cause a performance impact. If you want to remove an existing script from BusComp_PreInvokeMethod to improve performance, you must inactivate the appropriate record using Siebel Tools.
CancelOperation stops the execution of the underlying Siebel code associated with the event. However, if there is code in the same script following CancelOperation, that code runs regardless of the CancelOperation.
Used With
Server Script
