Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events >
BusComp_PreSetFieldValue Event
The PreSetFieldValue event is called before a value is pushed down into the business component from the user interface or through a call to SetFieldValue.
BusComp_PreSetFieldValue(FieldName, FieldValue)
String containing the name of the changed field
String containing the changed value
ContinueOperation or CancelOperation
The PreSetFieldValue event is called each time a field is to be changed or populated for a given business component.
When using a picklist to populate multiple fields, PreSetFieldValue is fired for each field that is populated. For example, you have an applet that you use to populate Last Name, First Name, and Contact ID. Therefore, PreSetFieldValue fires three times, once for each field.
CancelOperation stops the execution of the underlying Siebel code associated with the event. However, if there is code in the same script following CancelOperation, that code runs regardless of the CancelOperation. In the preceding example, if your script returns CancelOperation for a field, that field is not populated. However, PreSetVieldValue still fires for the other two fields populated by the picklist.
NOTE:  To prevent infinite recursions, if the PreSetFieldValue event is running it does not run again for the same business component instance, even if used on a different field in the business component.
Used With
Browser Script, Server Script
This Siebel VB example uses the PreSetFieldValue event to check if a quote discount is greater than 20 percent, and to take appropriate action if it is. For other examples of BusComp_PreSetFieldValue, read LoginId Method, and ExecuteQuery Method.
Function BusComp_PreSetFieldValue (FieldName As String,
               FieldValue As String) As Integer
'Routine to check if a quote discount>20%
'if it is, notify user and cancel operation
Dim value as Integer
Dim msgtext as String
   If FieldName = "Discount" then
      value = Val(FieldValue)
      If value > 20 then
          msgtext = "Discounts greater than 20% must be approved"
         RaiseError msgtext
         BusComp_PreSetFieldValue = CancelOperation
         BusComp_PreSetFieldValue = ContinueOperation
       End if
End If
End Function
The following is the equivalent example in Siebel eScript.
function BusComp_PreSetFieldValue (FieldName, FieldValue)
   var msgtext = "Discounts greater than 20% must be approved";
   if (FieldName == "Discount")
      if (FieldValue > 20)
         return (CancelOperation);
         return (ContinueOperation);
