Siebel Object Interfaces Reference > Interfaces Reference > Business Service Methods >
GetLastErrCode Method
The GetLastErrCode method returns the most recent error code.
Syntax
BusComp.GetLastErrCode
Argument
Description
Not applicable
Returns
The last error code as a short integer; 0 indicates no error.
Usage
After execution of a method, the GetLastErrCode can be invoked to check if any error was returned from the previous operation. The GetLastErrText method can be invoked to retrieve the text of the error message.
Used With
Mobile Web Client Automation Server
See Also
GetLastErrText Method
