Siebel Object Interfaces Reference > Interfaces Reference > Business Service Methods > GetNextProperty MethodWhen the name of the first property has been retrieved, this method retrieves the name of the next property of a business service. SyntaxReturnsA string containing the name of the next property of a business service, or a null string ( UsageAfter retrieving the name of the first property with GetFirstProperty, the GetNextProperty method should be used in a loop, to be terminated when a null string ( Used WithBrowser Script, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script ExamplesThis function returns the number of Property Sets that belong to the Business Service given in parameter. The following example is in Siebel eScript: function countPropSets(busService) while(propSetName != null && propSetName != "") The following example is in Java: public int countPropSets(SiebelService busService) catch(SiebelException sExcept) See Also |
Siebel Object Interfaces Reference |
