Siebel Object Interfaces Reference > Interfaces Reference > Business Service Methods > InvokeMethod MethodThe InvokeMethod method calls a method on the business service. This can be a documented specialized method or a user-created method. eScript SyntaxoService.InvokeMethod(methodName, InputArguments, OutputArguments) Siebel VB SyntaxoService.InvokeMethod methodName, InputArguments, OutputArguments
Browser Script SyntaxoutputPropSet=Service.InvokeMethod(MethodName, inputPropSet) ReturnsUsageBuilt-in business services work the same way as business component invoke methods. That is, you can call specialized methods on the service that are not exposed directly through the object interface. Run-time business services can hold user-defined methods, which must be implemented in scripts written in Siebel VB or Siebel eScript. The scripts must be written in these languages within Siebel Tools; however, they can be called through external interfaces. Although the InvokeMethod function does not return a value, the properties in the OutputArguments property set may have been modified. NOTE: The InvokeMethod method should be used only with documented specialized methods. Siebel Systems does not support calling specialized methods with InvokeMethod, unless they are listed in this book. Used WithBrowser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script, Web Client Automation Server See Also |
Siebel Object Interfaces Reference |
