Siebel Object Interfaces Reference > Interfaces Reference > Business Service Methods > PropertyExists MethodThis method returns a Boolean value indicating whether a specified property exists. SyntaxoService.PropertyExists(propName) ReturnsIn Siebel VB, an integer (0 for false, 1 for true); in other interfaces, a Boolean UsageBecause GetProperty returns a null string ("") for nonexistent properties, you should use PropertyExists() in an if statement to determine whether a specific property has been set. Used WithBrowser Script, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script |
Siebel Object Interfaces Reference |
