Siebel Object Interfaces Reference > Interfaces Reference > Control Methods > Applet MethodThe Applet method returns the parent applet object for a control. SyntaxReturnsThe parent applet of the control UsageObtaining the parent applet allows you to perform operations on the applet object, not just the control. Used With |
Siebel Object Interfaces Reference |
