Siebel Object Interfaces Reference > Interfaces Reference > Property Set Methods > GetNextProperty MethodThis method returns the next property in a property set. SyntaxReturnsA string representing the name of the next property in a property set UsageAfter retrieving the name of the first property with the GetFirstProperty method, GetNextProperty should be used in a loop, to be terminated when a null string ( Used WithBrowser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script, Web Client Automation Server ExampleFor an example, read GetFirstProperty Method. See Also |
Siebel Object Interfaces Reference |
