Siebel Object Interfaces Reference > Interfaces Reference > Property Set Methods >
InsertChildAt Method
This method inserts a child property set into a parent property set at a specific location.
oPropSet.InsertChildAt childObject, index
A property set to be made subsidiary to the property set indicated by oPropSet
An integer representing the position at which childObject is to be inserted
Not applicable
This method inserts the property set childObject at the location index. Index numbers start at 0. When a child property set is inserted, the property set previously at the location index has its index increased by 1, as do subsequent child property sets.
Used With
Browser Script, COM Data Control, COM Data Server, Java Data Bean, Mobile Web Client Automation Server, Server Script, Web Client Automation Server
See Also
AddChild Method
