Siebel Object Interfaces Reference > Java Data Bean Quick Reference >
Data Bean Methods for Java Data Bean
Table 39 lists a summary of the SiebelDataBean methods' syntax.
Table 39. SiebelDataBean Methods Syntax Summary
Attach Method
Allows an external application to reconnect to an existing Siebel session.
boolean attach(String sessionID) throws SiebelException
CurrencyCode Method
Returns the three-letter operating currency code.
String currencyCode()
Detach Method
Returns a string containing the Siebel session ID.
String detach() throws SiebelException
GetBusObject Method
Instantiates and returns a new instance of the business object specified in the argument.
SiebelBusObject getBusObject(String boName) throws SiebelException
GetProfileAttr Method
Returns the value of an attribute in a user profile.
String getProfileAttr(String attrName) throws SiebelException
GetService Method
Returns a specified service. If the service is not already running, it is constructed.
SiebelService getService(string serviceName) throws SiebelException
InvokeMethod Method
Calls the named specialized method.
String invokeMethod(String name, String[] args) throws SiebelException
Login Method
Allows external applications to log in to the Data Bean.
boolean login(String connString, String userName, String passWord) throws SiebelException
LoginId Method
Returns the login ID of the user who started the Siebel application.
String loginId()
LoginName Method
Returns the login name of the user who started the Siebel application.
String loginName()
Logoff Method
Disconnects the client from the server.
boolean logoff() throws SiebelException
NewPropertySet Method
Constructs and returns a new property set object.
SiebelPropertySet newPropertySet()
PositionId Method
Returns the position ID that describes the user's current position.
String positionId()
PositionName Method
Returns the position name of the user's current position.
String positionName()
SetPositionId Method
Sets the active position to the Position ID specified in the argument.
boolean setPositionId(String posId) throws SiebelException
SetPositionName Method
Sets the active position to the position name specified in the argument. Returns a Boolean value indicating if the method succeeded.
boolean setPositionName(String posName) throws SiebelException
SetProfileAttr Method
SetProfileAttr is used in personalization to assign values to attributes in a user profile.
boolean setProfileAttr(String attrName,String attrValue) throws SiebelException
Trace Method
The Trace method appends a message to the trace file. Trace is useful for debugging SQL query execution. This method does not trace Java standard output.
boolean trace(String message) throws SiebelException
TraceOff Method
TraceOff turns off the tracing started by the TraceOn method. This method does not trace Java standard output.
boolean traceOff() throws SiebelException
TraceOn Method
TraceOn turns on the tracking of allocations and deallocations of Siebel objects, and SQL statements generated by the Siebel application. This method does not trace Java standard output.
boolean traceOn(String filename, String Category, String selection)throws SiebelException
