Table 43. SiebelPropertySet Methods Syntax Summary
AddChild Method |
Adds subsidiary property sets to a property set. |
int addChild(SiebelPropertySet propertySet)
Copy Method |
Returns a copy of a property set. |
SiebelPropertySet copy(SiebelPropertySet propertySet)
GetChild Method |
Returns a specified child property set of a property set. |
SiebelPropertySet getChild(int index)
GetChildCount Method |
Returns the number of child property sets attached to a parent property set. |
int getChildCount()
GetFirstProperty Method |
Returns the name of the first property in a property set. |
String getFirstProperty()
GetNextProperty Method |
Returns the name of the next property in a property set. |
String getNextProperty()
GetProperty Method |
Returns the value of a property when given the property name. |
String getProperty(String propertyName)
GetPropertyCount Method |
Returns the number of properties attached to a property set. |
int GetPropertyCount()
GetType Method |
Returns the value stored in the Type attribute of a PropertySet. |
String getType()
GetValue Method |
Returns the value stored in the Value attribute of a PropertySet. |
String getValue()
InsertChildAt Method |
Inserts a child property set into a parent property set at a specific location. |
boolean insertChildAt(SiebelPropertySet propertySet, int index)
PropertyExists Method |
Returns a Boolean value indicating whether the property specified in the argument exists. |
boolean propertyExists(String propertyName)
RemoveChild Method |
Removes a child property set as a specified index from a parent property set. |
boolean removeChild(int index)
RemoveProperty Method |
Removes the property specified in its argument from a property set. |
boolean removeProperty(String propertyName)
Reset Method |
Removes every property and child property set from a property set. |
boolean reset()
SetProperty Method |
Assigns a value to the property of a property set specified in its argument. |
boolean setProperty(String propertyName, String propertyValue)
SetType Method |
Assigns a data value to a type member of a property set. |
boolean setType(String type)
SetValue Method |
Assigns a data value to a value member of a property set. |
boolean setValue(String value)
