Siebel Order Management Guide Addendum for Industry Applications > Using Network Ordering > Process of Upgrading Bandwidth at Network Sites > Updating Assets when an Order to Upgrade Bandwidth Is CompleteAs components needed to upgrade bandwidth are installed, convert the line items representing these components to assets, so you can track them for service and for change orders. For more information about assets, see Siebel Field Service Guide. For more information about converting orders to assets, see the section about workflow to apply an order to the service profile in Siebel Order Management Guide. NOTE: Before configuration, the Auto-Asset button can be used to convert line items to assets. However, during configuration, the Auto-Asset button is usually removed and the process is automated. If the Auto-Asset button has not been removed, the end user can use the following procedure. This task is a step in Process of Upgrading Bandwidth at Network Sites. To convert a line item representing a network component to an asset |
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
