Siebel Order Management Guide Addendum for Industry Applications > Using Network Ordering > Process of Disconnecting a Site from a Network >
Disconnecting a Network Node and Connections
When a salesperson disconnects a node from a network, all connections associated with that node are automatically disconnected.
This task is a step in Process of Disconnecting a Site from a Network.
To disconnect a node and all associate connections
  1. Navigate to the Networks screen.
  2. In the Networks list, select the network whose node you are disconnecting.
  3. Click the Nodes view tab.
  4. In the Nodes list, select the node.
  5. In the Nodes list, click Disconnect.
    A new quote is created. The node and any connections that are connected to it are copied to the quote and marked for Delete.
Siebel Order Management Guide Addendum for Industry Applications Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
