Siebel Order Management Guide Addendum for Industry Applications > Using Network Ordering > Process of Disconnecting a Site from a Network > Updating Assets After Disconnecting a Network SiteWhen the work of disconnecting each component at a network site is done, update the customer's assets so they no longer include the component. For more information about converting orders to assets, see the section about workflow to apply an order to the service profile in Siebel Order Management Guide. NOTE: Before configuration, the Auto-Asset button can be used to convert line items to assets. However, during configuration, the Auto-Asset button is usually removed and the process is automated. If the Auto-Asset button has not been removed, the end user can use the following procedure. This task is a step in Process of Disconnecting a Site from a Network. |
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
