Siebel Order Management Guide Addendum for Industry Applications > Using Network Ordering > Process of Ordering New Networks > Converting a Completed Network Order to AssetsAs components of the network order are installed, convert the line items representing these components to assets, so you can track them for service and for change orders. For more information about converting orders to assets, see the section about workflow to apply an order to the service profile in Siebel Order Management Guide. NOTE: Before configuration, the Auto-Asset button can be used to convert line items to assets. However, during configuration, the Auto-Asset button is usually removed and the process is automated. If the Auto-Asset button has not been removed, the end user can use the following procedure. This task is a step in Process of Ordering New Networks. |
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
