Siebel Order Management Guide Addendum for Industry Applications > Setting Up Network Ordering > Process of Defining Network Compound Products > Defining Products for the NetworkYou must define all the network elements as products, including the network product and the network components. This task is a step in Process of Defining Network Compound Products. Defining the Network ProductYou can define the network product for network ordering (for example, the frame relay) in the same way you define other customizable products using the Customizable Products view of the Administration - Products screen, but you must enter information in additional fields. Configurator rules are not required but can be used if needed. For more information about defining customizable products, see Product Administration Guide.
Defining Network Components as ProductsWhen customers order networks, your salespeople will add nodes and connections to the network, for example, ports and PVCs. You must set up each of these products using the Administration - Products screen, Customizable Products, Product Designer, and then Rule Designer to make sure that they choose only valid combinations of features for each node and connection. To allow the salesperson to add these components to the network, you must:
For more information about creating products and configuration rules, see Product Administration Guide. |
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
