Siebel Order Management Guide Addendum for Industry Applications > Setting Up Network Ordering > Process of Defining Network Compound Products >
Defining Error Messages for Compound Product Rules
Before you create simple expression rules for compound products, you must use the Unified Messaging Service to define the error messages that these rules display.
For more information about using the Unified Messaging Service to define messages, see Siebel Order Management Infrastructure Guide.
This task is a step in Process of Defining Network Compound Products.
To define error messages for compound product rules
  1. Navigate to the Administration - Order Management screen, then the Message Types view.
  2. In the All Message Types list, add a new record and complete the necessary fields, as described in Siebel Order Management Infrastructure Guide.
    The message that you enter in the Full Text field is displayed.
Siebel Order Management Guide Addendum for Industry Applications Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
