Siebel Order Management Guide Addendum for Industry Applications > Partner Asset-Based Ordering > Order Management with Standard Partner Commerce > Modifying an Order (Standard Partner Commerce)This feature allows an end user to modify a service item that is already provisioned. In this action, you can change product attributes or a feature or component of the service item. This procedure uses the workflows CUT eSales - Modify Products and Services Process and CUT eSales - Prepare Shopping Cart Process - Interactive, which are described in Workflows to Modify Products and Installed Assets. To modify an existing service item
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
