Siebel Order Management Guide Addendum for Industry Applications > Partner Asset-Based Ordering > Order Management with Standard Partner Commerce > Customizing an Item (Standard Partner Commerce)Standard Partner Commerce users customize items by selecting item components and attributes in a configuration session. To start a configuration session, the user clicks Customize. When the user exits the configuration session, the configuration is transferred to the shopping cart. NOTE: Only customizable or complex products can be customized. If the quantity of a configurable item is greater than one when the user starts a configuration session, the configuration is applied to each of the configurable items. For example, a user adds a configurable Residential Phone Service Package to the shopping cart and specifies 4 in the Qty field, and clicks Customize. When the user exits the configuration session, the configuration is applied to all 4 of the Residential Phone Service Packages. A Configurator license is required to configure customizable products.
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
