Siebel Order Management Guide Addendum for Industry Applications > Partner Asset-Based Ordering > Order Management with Standard Partner Commerce > Adding Bulk Items to the Shopping Cart (Standard Partner Commerce)Business users frequently need to order customizable items in bulk. For example, a business user may order 20 customizable phone lines for installation at the same location. Rather than configure each instance separately, users can configure the item once and apply the configuration to all the instances. They can then adjust the configuration of individual instances of the item as needed. This procedure uses the workflow CUT eSales - Ungroup Quote, which is described in Workflow to Ungroup Quotes. To add bulk items to the shopping cart
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
