Siebel Order Management Infrastructure Guide > Data Validation Manager > Process of Administering Data Validation Rules >
Activating a Data Validation Rule Set
The final step in administering data validation rules is to activate the rule set. Only then can it be executed by the Data Validation Manager business service.
After you have added and defined all rule set arguments and rules, activate the rule set. After you activate the rule set, it becomes read-only and can not be edited.
You can only define arguments and rules for validation rule sets that have a status of In Progress. If you want to revise an existing rule set, see To revise an existing validation rule set.
This task is part of Process of Administering Data Validation Rules.
To activate a rule set
  1. Navigate to the Administration - Data Validation screen.
  2. In the Rule Sets list, select the rule set you wish to activate.
    NOTE:  The status of the rule set must be In Progress in order for you to activate it.
  3. Click Activate.
    Clicking Activate changes the status of the rule set to Active and makes the record read-only.
Siebel Order Management Infrastructure Guide Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
