Siebel Order Management Infrastructure Guide > Data Validation Manager > Process of Invoking the Data Validation Manager Business Service >
Invoking Data Validation Manager from a Runtime Event
You can invoke the Data Validation Manager business service from a runtime event. When the specified runtime event occurs, the application invokes the business service. To invoke the business service from an event, you first define the event in the Administration - Runtime Events view. For more information on runtime events, see Personalization Administration Guide.
This task is part of Process of Invoking the Data Validation Manager Business Service.
To define a runtime event to invoke the Data Validation Manager
  1. Navigate to the Administration - Runtime Events screen, then Action Sets view.
  2. In the Actions Sets list, add a record and complete the necessary fields.
    Some fields are described in the table that follows.
    Field
    Comments
    Action Type
    Specifies the type of action. Select BusService.
    Sequence
    Number describing the order in which the action occurs. Execution begins with the action with the lowest sequence number. Actions with the same sequence number are executed in random order. Actions occur in sequence until all actions are completed.
    Active
    Check the box to indicate whether the action will be triggered or not. Inactive actions are ignored when the event occurs. This is a quick way to turn off an action without changing the start and end dates.
  3. In the More Info form, complete the fields using the values described in the table that follows.
    Field
    Value
    Comments
    Business Service Name
    Name of the business service to invoke, if the conditional expression evaluates to TRUE and the type is BusService.
    Enter the value exactly as shown.
    Business Service Method
    Validate
    Method to invoke on the business service.
    Business Service Context
    Example:
    "Rule Set Name", "Validation", "Enable Log", "Y"
    These input arguments are equivalent to those presented in Step 2.
    Name-value pairs to specify the inputs to the business service method. Both the name and the value must be enclosed by quotation marks and separated by a comma and a space after the comma.
    CAUTION:  Failure to use the syntax specified in the Business Service Context field can result in errors.
  4. In the link bar, click Events to associate an event with the action set.
  5. In the Events list, add a record and complete the fields as described in the table that follows.
    Field
    Comments
    Name
    Optional. Select an event alias from the drop-down list. Selecting a name automatically populates the Object Type, Object Name, Event, and Subevent fields. This is based on the event template created in the Event Aliases list.
    For more information on creating event aliases, see Personalization Administration Guide.
    Sequence
    Required. An event can trigger multiple action sets. Enter numbers in this field to control when the action set associated with this event in this record executes relative to other action sets associated with this event.
    Object Type
    Required. Select BusComp from the drop-down list.
    Object Name
    The name of the application, business component, or applet (depending on the object type) to which the event occurs.
    Event
    Required. Select from the drop-down list. The choices depend on which object type you choose. Valid values include:
    • Use the PreWriteRecord business component event if you want to control whether a record can be written to the database, based on the outcome from the validation.
    • Use the PreDeleteRecord business component event if you want to control whether a record can be deleted from the database, based on the outcome from the validation.
    Action Set
    Required. Select an action set to run when the event occurs. The Name name is defined in the Action Sets view tab. For more information, see Step 3.
  6. Either close down and relaunch the server or mobile clients, or select Reload Runtime Events from the applet menu.
Siebel Order Management Infrastructure Guide Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
